Index > @ the Pickup Bed (General Topics) > Thread: Fuse keeps popping
Xp882
posted June 30, 2009 10:56 PM
Fuse keeps popping
Flasher backlamp fuse keeps popping and my gauges are not working just started out of the blue any ideas?
Klaus45
On two wheels
posted July 01, 2009 06:48 AM
Edited By: Klaus45 on 1 Jul 2009 06:49
Could be a couple of things adding up, (or not) -- you might have one or more bad grounds, as well as a possible short, and/or wiring compromised within the insulation...
I'd start by checking out the relay box at the driver's left knee. Beware the typically rusty bolts/(screws?) holding it to the wheelhouse -- there's some of your candidates for a bad ground --.
Check and clean your fuse block (and underneath it) next...
...of course, it could just be something behind your instrument panel...
Good luck!
posted July 01, 2009 09:01 AM
Had the same issue about 15 years ago. Had someone do exaust work. Had a loose wire for brake light short on muffler. Kept blowing a fuse and lossing dash and lights.
It only happened when the truck was running over 40 mph.
0.022315979003906 seconds processing time
