Index > @ the Pickup Bed (General Topics) > Thread: igniotion cuts out at higher rpm
fliboyz6
great
posted February 22, 2009 04:21 PM
finally got the time to put the carb put back in and with a little frustrartion it fired up i then took it for a test drive and it would not get above 60mph on the free way after i played with the carb and the timing it idles much better but once again it punks out at higher rpm the tac bounces 500 to 1000 rpm...... any ideas?
StumpDrummer
posted February 22, 2009 06:53 PM
Im new to this forum
but are the coils new have you cleaned out the distributor cap wash it out with soap and water with a rag check to see if rotor button is good crank it at night and see if the plug wires are sparkin...i had a honda that didnt start sparkin though the wires till around 2500rpm it was wierd
are the points clean plugs too also look for damaged wires throughout the harness carefully
How can we possibly know where we are going(as a people)if we dont even know where we come from
kansei
Wankelized
posted March 02, 2009 06:27 AM
Just a few more thoughts...
Are we certain it's the ignition cutting out and not fuel issues?
Ignition:
If you're still running the points and condensers, replace them and make sure the new ones are properly gapped and the dwell is set right. Also, as stated above, make sure the cap and rotor are clean and there isn't too much wear or corrosion.
Fuel:
Also sounds like maybe you have the floats improperly set, or may have another issue in the carb such as a blocked air bleed, bad accelerator pump, or maybe even a stuck secondary linkage?
Neal.
Neal A.E. Swigert
Greenville, Michigan
1974 REPU Resto Project
1976 808 Wagon
1977 Cosmo
1978 Savanna RX-7 GT
1980 Leather Sport RX-7
1980 Petty Targa RX-7 #11
1985 GSL-SE RX-7
1988 RX-7 10th Ann
1993 RX-7 VR Touring
0.023823976516724 seconds processing time
