Index > @ the Pickup Bed (General Topics) > Thread: my 74 repu
Thread: my 74 repu [' This thread is 2 pages long: (1) 2 ']
blwfly
posted January 15, 2009 08:19 AM
Edited By: blwfly on 15 Jan 2009 08:22
my 74 repu
just like to show my project owned it for a year now cant wait to start.
im selling my rx7 to fund the project waitin on the money lol.
so i have found out that the hood and front bumper are from a ford coriuer and maybe the side mirrors can any one confirm that, the bumper is defintly from another truck.
74 repu getting a s4 t2
bliffle
posted January 15, 2009 09:55 AM
It's a beauty. Wish it were mine. Color matches my 83 RX-7.
fliboyz6
great
posted January 24, 2009 09:58 PM
you wanna sell the header thats on there???
blwfly
posted January 24, 2009 10:30 PM
sorry the headers in my rx7 the motor in the repu is a 12a.
but i have a s4t2 for it instead.
posted January 25, 2009 01:10 PM
I'm doing an S4 T2 in the white truck for PercentSevenC.
blwfly
posted January 25, 2009 06:49 PM
seems the pictures went away..
Klaus45
On two wheels
posted January 26, 2009 09:02 AM
A variety of truck mirrors ended up on REPU's... the kind you have will ultimately compromise the door sheetmetal around the lower mount, if they've not done so already. Unless you really like those particular ones, you might want to look around for some of the rare, REPU-specific ones...
If your hood was from a Courier, I'd expect to see holes in the front edge, where the 'FORD' logo was mounted; instead, I'm noticing it looks like there was a proper hood trim attached there at one time.
You're not located all that far from me, perhaps we ought to get in touch?
blwfly
posted January 26, 2009 06:28 PM
i thought the mirrors we out of place.
i was told it was from a Courier but u have a point .
heres my email Klaus45
christoph_1300@hotmail.com
im on msn messanger to.
blwfly
posted April 11, 2009 09:23 AM
little update.
just purchaced this stuff from atkins.
Overhaul Kit, 87-88 13B T (B)
Overhaul Gasket Kit (8AF4-10-271)
Apex Seals and Springs
Corner Seals and Springs
Side Seals and Springs
Viton Oil O Rings (Inserts)
Oil O Rings (Metal)
Front and Rear Main Seals
Pilot Bearing and Seal
Thermal Pellet
Hylomar Sealant
Rotor Bearing For 69-92 Rotary Engines
3 Window Main Bearing for 74-92 RX7 All
Rear Rotor Housing 87-88 RX7 Turbo
Main Stationary Gear Bearing Tool to be used with a hydraulic press Rotor Bearing Tool. for use with Hydraulic Press
Clutch Kit- NEW - 87-88 13B Turbo Rx7
Contains: Clutch Disc, Pressure Plate, Throwout Bearing, Pilot Bearing & Seal
Oil Pump Chain for 86-95 All Rotary Engines
CoolantTester Atkins Rotary Designed Coolant Pressure Tester
Thermostat for 69-88 Rotary Engines
Thermostat Gasket
this stuff from japan2la on the froum
Front and middle sideplate
matched S4 TII rotors
Spacer between TB and UIM FREE
S5 Staygears front and rear (yes hardened)
S4 TII BPS sensor
been a longtime to get this far lol
also heres my thread on my wireing nightmare
http://www.rx7club.com/showthread.php?t=830144
cheers
kiwi
RW-7
posted April 12, 2009 10:03 PM
Sweet Chris! We will have to get our REPU's on the road together one of these days!!
blwfly
posted April 13, 2009 09:56 PM
Edited By: blwfly on 13 Apr 2009 22:00
rebuild kit
stock t2 clutch excedy
new rotor housings
atkins corner seals
shit load of tools i got for cheap
blwfly
posted April 11, 2010 09:48 PM
Edited By: blwfly on 11 Apr 2010 21:53
havnt updated on this site for ages so heres some pics.
not alot left to finish the truck soo exciting..
basicly the driveshft needs to be made and the exhaust fabbed up.
EricRyan
posted April 12, 2010 04:38 PM
Wow! Good work. You really don't NEED an exhaust.... Just run it out the header to go around the block once or twice :)
blwfly
posted April 12, 2010 05:14 PM
lol thanks
i cant have any driving violations so i will not do that.
but i do have 2 3" in/out borla xr1 racing mufflers just need to buy a 3"tube and mandrel bends. the 3" exhaust is for the turbo in the future a gt35r maybe.
Klaus45
On two wheels
posted April 12, 2010 09:44 PM
Lookin' good, Chris!
Be interesting to hear how much those Borla's resonate, especially wihtout a turbo...
blwfly
posted April 13, 2010 07:40 PM
Edited By: blwfly on 13 Apr 2010 19:41
yeah i cant wait to hear what it sounds like. i really dont want a loud truck but i guess im screwed untill i get the turbo.
you should come over sometime,
cheers
chris
blwfly
posted May 10, 2010 05:36 PM
[URL=http://img163.imageshack.us/i/cimg0024r.jpg/][/URL]
had this made on friday
measured to be 57 1/4 from the 3rd member flange to the rear of the transmission
the t2 spline count is 25 and od of the splines is 27.30mm from that the local shop had it done in 2hours also put all new joints in. went for a small drive got up to 2nd gear but its way to loud with no mufflers
spokanerxdude
Less cubes... More balls
posted June 25, 2010 04:52 AM
This is a example of why you don't take your tool box out partying with you, it pucks all over the floor. Sorry I have a weird sense of hummer.
509-998-9024
posted June 25, 2010 04:59 PM
Driveshaft?
Did the shop just replace the yoke? If so, do you have a manufacturer and part #?
I had one done years ago for a T2 trans and the shop just replaced the yoke. I sent a friend to the same shop recently to get his done and they had to cut and weld and charge alot more. They couldn't remember doing mine which was just a yoke swap for $100.00.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
posted June 25, 2010 05:00 PM
Forgot to ask, any updates on your truck?
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1996 Aprilia RS 250
2004 Mazda RX8
2006 Yamaha Banshee
0.050474882125854 seconds processing time
