Index > @ the Pickup Bed (General Topics) > Thread: Aftermarket steering wheel help please!!
micah
posted April 27, 2008 01:30 PM
Looking for a quick release hub kit. I do know of the grant 3hole kit,but will it work with a more modern quick release like nrg for example. I'm interested in a shutt steering wheel that matches my shift and shift boot, which works with the new 6 hole kits,,,,any advice would be appreciated...OH, im not looking to sell my wheel guys,,,,,dyno tuning in a week,,,,just finishing heat shielding and stuff,,,and had to go bigger on the exhaust bell on the turbo, was getting bad boost creep, gauges added too...
TimPA136
posted April 28, 2008 08:01 PM
Edited By: TimPA136 on 28 Apr 2008 20:04
Tuning and steering wheel
I have heard of grantproducts.com Not a recomendation but a place to check.I'm guessing we are talking the same place.
P.S. Keep a giant fan on your baby while on the Dyno.
Are you tuning for premium gas?
Tim
micah
posted April 28, 2008 10:31 PM
well if you mean 91 octane yes,,,im not going over 15 pounds, i dont want to push more horse just cause i can. i would like between 300 and 350 to the wheels. That's more than enuff i feel.
TimPA136
posted May 04, 2008 12:39 PM
That sounds hot to me.
Any luck with the steering wheel adapters?
Tim
Micah
posted May 04, 2008 03:24 PM
Edited By: Micah on 4 May 2008 15:26
I still need help with an adapter for newer style steering wheels, I know of the grant 3 hole wheels, but that's not what I want. Please any more suggestions?
posted May 04, 2008 05:30 PM
I think the adapter on my truck also will fit first gens as well. If what you are looking for will fit a first gen then it should work. Good luck.
posted May 06, 2008 01:50 PM
Edited By: Draggin_2600i on 6 May 2008 14:01
i used to have a kit on my old MAZDA B2600i.. the grant one.. i think the wheel is five hole.. i think it would be good to email NRG about their adapter to see if it is compatible with the grant one. I have been considering doin exactly that same thing ever since my buddy put the nrg quick release on his integra a year ago.. not yet ready for it though.. from what i recall about those hubs, as long as you can get the adapter for a wheel on the column, the hub bolts onto that.
So the one you mention, the three hole one, bolts onto a spacer.. on the face of that spacer is where you bolt the wheel on.. the nrg hub would bolt onto this spacer instead and then the wheel to the nrg hub.. if it seems like it might be to far out nrg has a shallow quick release too. from the looks of their site it the quick releases come drilled for more than one type of wheel..
I personally did not really want the quick release for anything flashy.. i want it for the wheel lock they have for those hubs.. good luck.. if i find out anything i will post the info here.
posted May 06, 2008 02:36 PM
Edited By: Draggin_2600i on 6 May 2008 14:43
here are some links..
http://www.nrginnovations.com/products/index.php#block1
for the nrg hubs..
http://www.grantproducts.com/p-309-3597.aspx
for the old mazda hub i had..According to the search feature on the grant site it is also the same for the repu. so kit 3597. there is also a momo adapter 5702 that is supposed to be for the mazda trucks.
http://www.grantproducts.com/c-226-installation-accessories.aspx
this shows they have their own momo adapter.. and the extension like the ones that come with the wheels.. seems you can get shallow ones.. i think after doing this deeper research that it is definitely doable.. the first step would be to buy the hub to fit the repu column and go from there.
dont forget to use thread locker.. lol.. i hated the wheel gettin loose due to vibration.. but i did have a teeth chattering system back then..
micah
posted May 07, 2008 07:28 PM
Edited By: micah on 7 May 2008 19:35
Thanks soo much, i did find an adapter for the 3hole grant to a momo 6 hole.I'll buy the thin nrg quick release hub, cause the 3 hole to 5 adapter is 1 1/2 " and the thin nrg is also. So its three inches, closer to you in all. Should be ok cause the wheel will be smaller. Alot better then the old wheel touching my legs hehe, Thanks Again!!! So close to getting to that dyno, hopefully this
sat,,,may 10th
posted May 08, 2008 09:41 PM
No prob.. keep in mind gran also sells some short spacers.. even though they are five hole the nrg adapter should be universal. either way you can modify it later but at least the most expensive stuff will be done. hopefully soon i will have the time to go hang out with some of you guys when there is a meet.. Good luck with the dyno.
micah
posted May 09, 2008 02:32 PM
K, the guys got my new 1.15 ar for the turbo on, exhaust is wrapped ,,,dyno for sure now, shooting a short quicktime for utube,,,,and will post dyno sheet.
0.0279541015625 seconds processing time
