Index > @ the Pickup Bed (General Topics) > Thread: Wipers not returning where they should...
MAZDAMARK
posted September 11, 2007 07:26 AM
Has anyone seen this problem before? Unless I time it just right when I turn the wipers off, the wipers will just stop where they are when the switch is turned instead of returning to the bottom of the windshield. IIRC, this usuall means the wiper switch is shot... Does this sound right? Also, are all the the wiper controls located in part of the steering colum/stalk combination stuff? Or is there another module under the dash or something that I should worry about.
Thanks
94 RX7
89 RX7 GTUs
85 GSLSE
88 323 GTX
1975 REPU
posted September 11, 2007 09:18 AM
Don't worry...
...just time it right. (After all, you now own a vintage rotary truck!)
Of course, if it really bugs you, you could start trying to improve matters...
posted September 11, 2007 07:52 PM
Wipers
The part/s that returns the to park is in the wiper switch on the column and under the hood. Just track the problem down with your multimeter.
Manteca Mazda Asylum
posted September 12, 2007 11:56 AM
If there are no intermittent shorts, etc. ...
...hidden inside any of the wires, (for example), a teensy little dab/squirt of 'Cramoline' or 'Caig' brand "De-ox-it" type professional electronics contact cleaner at each and every connector/switch/etc., might work wonders. It's been a lifesaver for me a good number of times, on many a connection!
posted September 16, 2007 10:05 AM
The ground might be bad. That usually affects the park function.
0.029001951217651 seconds processing time
