Thread: lug nets and wheels
gdw3138
posted August 25, 2007 05:56 PM |
lug nets and wheels
Can any one tell me the diameter and pitch of the lugs? I need to replace some of my lug nuts. I have been looking for replacement wheels, but I am not having much luck in the Seattle area. I currently have sleeve style lug nuts but the only wheel that I have found was a 15" Mitsubishi, which also uses the sleeve type. However the sleeve diameter is 3/4 and mine is ~5/8". Few of the wheels that I have found are for Chevys and the center is too small and the offset is not right, too negative. I'm looking for a 15",3.5 center, 3.5-3.75" offset. If I can find net lugs nut, both RH and LH, Iwill probably go with the Mitsubishi rims. Thanks.
dryenko
posted August 26, 2007 04:26 AM |
Toyota wheels from Tundra and Tacoma fit just fine..
That way you can use original type tapered lugnuts, and these are available from places like Discount tire.
repu510
posted August 26, 2007 04:04 PM |
I bought a set of M12 x 1.5
I think they are the same as some Hondas also.
Some tire shops will let you test fit lug nuts too. I was lucky enough to have an old set of lug nuts from my old Honda that happen to fit.
