Index > @ the Pickup Bed (General Topics) > Thread: Upgrade to fuel injection
CCRider
posted January 25, 2007 02:03 PM
has any one put a new rx7 fuel injected rotary engine in there repu? i was wondering how difficult it would be?
posted January 25, 2007 03:27 PM
check out the gallery
http://www.mazdarepu.com/Gallery/index.php3?album=rtrypwrs++repu&photo=uploads/Aut_0005.jpg
moon
posted January 26, 2007 04:15 PM
where did you get the bedliner??? pickup looks good. been looking for a bedliner for years. looks like it was made for it. who makes it?
thanks
moon
rotaryguyseth
posted January 29, 2007 07:11 PM
im in the procoss of doing the same thing, did you use a stand alone ecu or did you use the stock one? if you used the stock one how hard was it too work?
i want to use a stock ecu because i dont want to deal with tuning the truck.
posted January 29, 2007 07:29 PM
Not my truck
Its just one in the gallery, Not sure who's it is. Good luck with your project, I'm doing what Dan did. TII
rotaryguyseth
posted January 30, 2007 12:21 PM
dam i wanted to do a TII put i have all the parts to do a NA it will only cost me the price of a seal kit and some springs.
G
posted May 14, 2007 09:29 PM
It looks to be the stock ECU as the OE emissions soleniods and mass air flow unit are still there
MattREPU
posted May 28, 2007 12:52 PM
EFI
I have GSL-SE EFI in my truck + turbo.
It's not the same as T-II, but the process is the same. I have done T-II in an 80 RX-7
I traced out the whole engine harness (with help from an 84 shop manual) identifying all the point where Power / Ground needed to be. Once I knew that, I had to run a couple of additional wires within the harness to simplify the connections to the chassis. The end result was the engine harness making a single connection for +12, Ground, IG-, and Start +12.
It was well worth the effort to trace out the harness. I did the same setup on my 83 RX-7 years ago and not only was it a pain, it was an ugly install. Getting the harness ready made the install way easier.
The pinout diagram for the ECU is the most important one to have, but there are a couple of places other than the end of the harness that would normally connect to the body harness under the dash were you need to run +12. Most noteably the two connections just past the firewall gromet.
As side notes...
The SE intake is tiny. I lost a lot of power on the big end compaired to the Delortoe 48's. 86-88 would be much better.
Headers ( at least the ones on my truck ) interfear w/ the 6-port actuators, and the line which feeds them.
Fuel is a bit of a pain. Low pressure drop is very important on the suction side of the pump. The pickup tube in my tank was perforated. I ended up taping a hole in the drain plug.
-Matt
74 REPU 6-port EFI
83 RX-7
0.024218082427979 seconds processing time
