get your old one recored. check out my other post on radiator cores. or you can get them custom built. griffin has templates to help you get a custom one.
so the actual radiator doesnt leak? just the rubber bushings are messed up? I eliminated the rubber bushings and just bolted the oil cooler on.
Wayland Chan
86sport
80widebody-project
heh. ok there are 3 major parts to a radiator. "header" bottom and top tanks. "core" the middle part with the actual fins and rows. and then theres that outer side parts on the sides(I wanna say mounting brackets). those little rubber bushings just un-screw off the mounting bracket. also. on the core the outermost peices of metal dont actaully hold any fluid. they just hold and protect the fins that are attached to the row. just find some short 10mm bolts. it should fit...i believe they may sell new rubber bushings @ mazdatrix.com
Wayland Chan
86sport
80widebody-project
