Index > @ the Pickup Bed (General Topics) > Thread: what tires to auto-x with?
posted February 16, 2006 11:42 AM
So I do need R compounds to autocross with afterall. Beating up my street tires sucks. So through connections I can get some Victoracer 205/50/15's new and shaved $200 for 4. But they're slower and heavier than the current Kumho V710 which I can get for $157 EACH!!!
And of course I need new (used?) aluminum rims for this and a 15x7 is as wide as I can go for 205, 15x8 or 9 for 225. So once I buy rims I'm committed to tire size. REPU is heavy and can use the extra 20mm width.
Decisions, decisions!!!
What to do?
posted February 16, 2006 12:09 PM
Budget vs. Results...
Rim/Tire size combo: To the limits of what fits... you may find that wider, hits... unfortunately.
7.5 x 15" rim with 205 50 15 worked with BFG R-1's.
8" or 9" rim might not, under hard cornering...
Light is good... sticky, better.
Shaving? That's for people who don't like to break 'em in themselves, right? :b
posted February 16, 2006 02:15 PM
I have 15x7 225/50/15 Dunlop SP2000's on the front already. They stick out but only rub sway bar at full lock. They don't rub ball joints or upper a arm 3.75 backspace.
Budget vs. Results, that really is it!!!!! + my REPU was down for 2 weeks when the dunlops were on national backorder and that won't happen with dedicated auto-x tires.
Is anyone in SoCal gonna auto-x this year????? I think one or two people sounded interested. Paul's turbocharged one with rear swaybar?
The Corvair club is having one in March, @ Camarillo airport, no date set but i'll advise when it's solid.
Shaved tires is so the tread blocks won't squirm under cornering. + less circumferance. + less heat. Heat cycling is another deal.
Still not sure if I should get the Victoracers.....
absolut
posted February 19, 2006 05:28 PM
combo that worked for me!
Shortly after getting my REPU I started reseaching what wheel/tire combo would work. I wanted a tire that I could drive to work on occation yet still take i to the track on the weekend and perform. Here's what I found.
I picked up a set of Discount tires "MB Motoring" wheels... Inexpensive yet still look good. I went for the Rocker 17x8. For rubber I chose the "Nitto 555" in a 255/45/17. I found that it is nearly stock diameter but much wider. That did not seem to be a problem, They only seem to rub up front when your turning hard and backing up at the same time... not often. I have Nitto tires on four vehicle now from the "Terra Grapplers" on my 4x4 to the 35 series "505's" on my lowrider S-15 and am very pleased with the performance and price. I think I spent $1100 on the whole package with warranty and all. I can honestly say if their warm and I drop the clutch on dry pavement I could swear the front tires come off the ground. Take a look at the Gallery "Brad C" group. That is what they look like and I have no clearance problems at all, and they will easily perform beyond what the truck can do in cornering.
Brad C
posted February 20, 2006 11:34 AM
I would expect...
...to be finding interference with the chassis/fenders the hard way, under auto-X extremes, using a combination that big...
posted February 20, 2006 04:00 PM
thanks for the info!
Good priced rims, but that combo is a little big for my lowered truck.
Trying to find some light (<21lbs) rims, got an occasional lead but not always a good one. One guy is selling his mag slotted rims off chevy truck, 15x8, but the rims are bent he says. ah well... still looking.
Absolut
posted February 21, 2006 09:25 AM
I was going to mention...
that this combo works well for me but I wouldn't want it on a lowered truck.
Check in your area for a wheel repair shop. There is a shop near me in Seattle called "Foster's Wheel Repair" that specializes in straightening wheels. If you got the wheels for free it may be cost efective to straighten them.
I understand the concern with weight and that is something to definently consider, however in my experience when your doing alot of cornering... auto-x... The benefit of a small sidewall verses a light wheel is great. For instance if I put a 35 series wheel on my rims I'm sure I could lower it at least 2 inces, however tires are more expensive.
In looking at what everybody else was running for wheels I was suprised to find that nearly every REPU I saw had 15" wheels.
posted February 21, 2006 09:27 AM
Edited By: klaus42 on 21 Feb 2006 09:29
You likely know the 'usual' issue:
...about the 'offset' being a bit too much towards the 'outside' on the front, with many/most wide(r) rims.
What works for (stiffened-up?), stock-ride-height on the street, may encounter clearance issues on the track...
Some *sticky*, stiff-sidewall tires do better on a <8" wide rim.
Different widths/offsets front vs. rear would allow stuffing more rubber under the truck, though... but then you can't rotate front-to-rear.
If the pic's legible,at all, you may want to check out the 'wheel worksheet' I posted on the MSN-site--. :)
A set of (new!) super-lightweight (not street legal) steel wheels might be the most beneficial, pound-per-$-saved option... though not nessecarily the prettiest.
posted February 21, 2006 11:29 AM
thanks for the info Klaus!
I've researched and the de facto auto-x rim width for a 225 tire is 8". Some even go to 9"!!!! So I'll go with common wisdon and get 8's. Easier to mount the tire compared to 9's too.
I want a 3.75" backspace, that is the same as I have on my street fronts. No clearance issues so far but I need to doublcheck if I'm bottoming out on the front bumpstops too.
There are some 15x8 3.75 BS 6 lug rims out there, just hard to find them light and reasonably priced. Still searching.
Found out that AR-23's are 25lbs in 15x8!!! Still lighter than the 29lb 15x8 steelies I have on the rear.
0.030679941177368 seconds processing time
