Index > @ the Pickup Bed (General Topics) > Thread: part numbers
mr-Repu
posted January 07, 2006 06:47 PM
part numbers
i need suspension and steering part numbers all of them, ball joints, bushes, tie rods, the lot.
if some one could help me out that would be very cool.
cheers
"Bow 2 the mighty M"
posted January 09, 2006 11:30 PM
You're down under, am I correct?
Do you prefer the original Mazda part #'s, or any of the aftermarket ones I can dredge up?
mr-Repu
posted January 14, 2006 09:15 PM
well i was going for nolathanes so that would be good but it would be good to have the genuine mazda part #s as well what ever is easy for you.
yea im down under good old new zealand.
cheers
posted January 15, 2006 09:43 AM
Edited By: klaus42 on 15 Jan 2006 09:44
If Dan could help us ressurrect access to it...
...nwaco (Ken) posted a thread in this very section precisely one year ago (Jan. 14th, 2004), entitled "Aftermarket Part Numbers........". (I just looked for it, but am not finding anything here prior to Jan, 17th, 2004...)
Still, no 'nolothane' part #'s I can recall--.
Before I start listing all the old Mazda numbers, what is the month and year your REPU was made? (Some part #'s change at very specific dates...)
posted January 15, 2006 02:51 PM
Part Numbers
I think this is the list he posted.
Part Description, Part Number, Year, Qty Per Vehicle
FRONT SUSPENSION
MOOG
Upper Control Arm Shaft Kit, K9154, 74 -77, 2
Lower Control Arm Bushing/Kit, K9178,74 -77,2
Upper Ball Joint, K9026, 74 -77,2
Lower Ball Joint, K9049, 74 -77,2
Sway Bar Link/Kit,K447, 74 -77,2
Sway Bar Frame Bushing/Kit, K9246, 74 -77, 1
Steering
MOOG
Idler Arm
IMPROVED DESIGN, K9096, 74 -77, 1
Idler Arm Repair Kit, K9088, 74 -77, 1
Inner Tie Rod End, ES2074R, 74 -77, 2
Adjusting Sleeve, ES2729S, 74 -77, 2
Outer Tie Rod End, ES2073L, 74 -77, 2
Stabilizer Cylinder, SSD63, 74 -77, 1
Stabilizer Kit, SSD32, 74 -77, 1
Brakes and Wheel Bearings
WAGNER
Front Anti Squeal Kit, SH048-5, 77, 1
RECOMMENDED REPLACEMENT IS ORGANIC
Front Disc Pads, 7009, 77, 1
Front Left Caliper With Pad,
QUICKSTOP, L107378, 74 -77, 1
Front Right Caliper With Pad
QUICKSTOP, L107379, 74 -77, 1
FITTED, SH048-5, 77, 1
Front Premium Non Asbestos Pads
THERMOQUIET, PD76, 77, 1
LEE MANUFACTURING
Front Caliper Kit, 16008, 74 -77, 2
WAGNER
Front Left Rebuilt Caliper, CR107378, 74-77, 1
Front Right Rebuilt Caliper, CR107379, 74-77, 1
QUICKSTOP, L107378, 74-77, 1
QUICKSTOP, L107379, 74-77, 1
LEE MANUFACTURING
Front Disc Hardware Kit, 15536, 74-77, 2
SUPERSEDED, 15536-2, 74-77, 2
Front Pin/Key Retainer, 15352, 74-77, 1
SUPERSEDED, 15352-2, 74-77, 1
GIBSON PRODUCTS
SUPERSEDED, 15536-1, 74-77, 2
WAGNER
Rear Rebuilt Brake Shoes
10 1/4" X 1 49/64", 395, 74-77, 1
Rear Premium Shoes
THERMOQUIET
10 1/4" X 1 49/64", PAB395, 74-77, 1
WAGNER
Rear Wheel/Cylinder-Left
13/16", F100750, 74-76, 1
Rear Wheel/Cylinder-Right
13/16", F100751, 74-76, 1
Rear Wheel Cylinder Kit
13/16", F100969, 74-76, 2
Rear Brake Hose
13/16", F100785, 74-76, 1
13/16", WC100750, 74-76, 1
13/16", WC100751, 74-76, 1
13/16", WK100969, 74-76, 2
Rear Brake Hose
13/16", BH100785, 74-76, 1
WAGNER
3/4" - upper, F100697, 77, 1
3/4" - upper, F100698, 77, 1
Rear Wheel Cylinder
3/4" - lower, F100696, 77, 2
3/4", F100967, 77, 2
3/4" - upper, WC100697, 77, 1
3/4" - upper, WC100698, 77, 1
Rear Wheel Cylinder
3/4" - lower, WC100696, 77, 2
3/4", WK100967, 77, 2
WAGNER
Remanufactured Master Cylinder
w/PWR BRAKES, R131616, 74-77, 1
Wheel bearings and seals
BOWER/BCA
Front Outer Bearing, 30204, 74-77, 2
Front Inner Bearing, 30206, 74-77, 2
Rear Inner Bearing, 30208, 74-77, 2
NATIONAL
Front Inner Seal, 1992, 74-77, 2
Rear Outer Seal, 1994, 74-77, 2
Rear Inner Seal, 473823, 74-77, 2
Clutch and Flywheel
BOWER/BCA
Release Bearing Assembly
225MM CLUTCH, FC1723C, 74-77, 1
Pilot Bearing, 152016, 74-77, 1
Gaskets & "Seals
NATIONAL
Rear Main Seal, 226840, 74-77, 1
Timing Cover Seal, 2025, 74-77, 1
Timing Cover Seal
REPAIR SLEEVE, 99169, 74-77, 1
Manual Transmission
BOWER/BCA
Front Transmission Bearing
4B, 4TA
4 SPD MAN TRANS, 306L, 74-77, 1
4R, 4 SPD MAN TRANS, 307L, 74-77, 1
5R, 5 SPD MAN TRANS, 307L, 74-77, 1
Countershaft Bearing
FRONT
5R, 5 SPD MAN TRANS, 5205KLE, 74-77, 1
Rear Transmission Bearing
5R, 5 SPD MAN TRANS, 305, 74-77, 1
Auto Transmission
NATIONAL
Automatic Transmission Front Pump Seal
JATCO 3N71, 2025, 74-77, 1
REPAIR SLEEVE JATCO
3N71, 99166, 74-77, 1
Automatic Transmission Rear Seal
JATCO 3N71
SUPERSEDED, 1216, 74-77, 1
JATCO 3N71, 1216N, 74-77, 1
Joints & Drive shafts
BOWER/BCA
Center Support Bearing, 205, 74-77, 1
PRECISION U-JOINT CORPORATION
Joint
ALL LOCATIONS, 397, 74-77, 1
Drive Axle Parts
BOWER/BCA
Front Pinion Bearing
REAR AXLE, 30306, 74-77, 1
Rear Pinion Bearing
REAR AXLE, 30307, 74-77, 1
NATIONAL
Pinion Seal
REAR AXLE
FRONT, 712011, 74-77, 1
Pinion Seal
REAR AXLE
FRONT REPAIR SLEEVE, 99157, 74-77, 1
Battery Parts
POWERPATH
OE INCLUDES BATTERY & BODY
GROUND STRAP IN A SINGLE CABLE
Battery/Switch Cable, 715534, 75-77, 1
Battery/Ground Cable
REQS FOLLOWING COMPONENT, 712234, 75-77, 1
Battery/Ground Cable, 712394, 75-77, 1
Ignition & Electrical Parts
CHAMPION WIRE & CABLE
O.E.M. INCLUDES BATTERY AND BODY GROUND STRAP IN A
SINGLE CABLE
Battery/Switch Cable, 64046, 74-77, 1
REQS FOLLOWING COMPONENT, 64010, 74-77, 1
Battery/Ground Cable, 64009, 74-77, 1
SUPERSEDED, 780136, 75-77, 1
Battery/Switch Cable, 781136, 75-77, 1
SUPERSEDED, 780119, 75-77, 1
Battery/Ground Cable, 781119, 75-77, 1
BOWER/BCA
Front Alternator Bearing
50, 63 AMP, 203FF, 74-77, 1
60, 65, 70 AMP, 302CC, 77, 1
Rear Alternator Bearing
50, 55, 60, 65 AMP, 201CC, 74-77, 1
Fuel
CARTER
Electric Fuel Pump
UNIVERSAL -
EXC w/FUEL INJ, P60504, 74-77, 1
Cooling
CARTER
New Water Pump, FP1730, 74-77, 1
Vision & Windshield
ANCO
New Washer Pump, 65-01, 72-77, 1
Aerovantage Blade
KWIK CONNECT, 91-14, 72-85, 2
Winter Blade
w/ADAPTER, 30-13, 72-85, 2
Wiper Blade
SPECIALTY BLADE, 25-14, 72-85, 2
Aerovantage Refill
METAL FRAME - FITS 91 SERIES, 19-14, 72-85, 2
Aerovantage Refill
- FITS 91 SERIES
PLASTIC FRAME, N14R, 72-85, 2
Anco Type Refill
METAL FRAME, 12-14, 72-85, 2
Aerovantage Blade
Winter Blade
Wiper Blade
Aerovantage Refill
METAL FRAME - FITS 91 SERIES, 19-14, 72-85, 1
Aerovantage Refill
- FITS 91 SERIES
PLASTIC FRAME, N14R , 72-85, 1
Anco Type Refill
METAL FRAME , 12-14, 72-85, 1
POWERPATH
Lifetime Pro Wires, 700187, 74-77, 1
5 Year 50,000 MILE WIRES, 60334, 74-77, 1
5 Year 50,000 MILE WIRES, 780034, 74-77, 1
Lifetime Wires, 60034, 74-77, 1
CHAMPION SPARK PLUG
SPARK PLUG GAP, '.040 74-77
POINT GAP, '.018, 76-78
POINT DWELL, 55-61, 76-78
IGNITION TIMING
TRAILING,
w/VACUUM HOSE CONNECTED, 20ATDC, 77-78
IGNITION TIMING - LEADING
w/VACUUM HOSE CONNECTED, 5ATDC, 77-78
FIRING ORDER, 1-2, 72-92
Manteca Mazda Asylum
mr-Repu
posted January 21, 2006 12:58 PM
its a 75.
posted January 22, 2006 11:38 AM
Mazda Factory Part Numbers:
0603 99 354B Joint Set, Upper Ball
0603 99 356 Joint Set, Lower Ball
0603 34 153 Bush, Rubber (Stabilizer) Q'ty: 8
0603 34 156 Rubber, Stabilizer Q'ty: 2
0633 34 673 Seal, Dust-Upper Arm Shaft Q'ty: 4
0193 34 820 Bush, Rubber-Lower Spindle Q'ty: 4
1854 32 250A Link, Center
1854 32 320 Idler
1854 99 322 Socket Set Q'ty: 2
1854 99 324 Socket Set Q'ty: 2
mr-Repu
posted January 29, 2006 01:06 PM
thank you all very much for posting up the part numbers.
cheers
haydon
0.030106782913208 seconds processing time
