Index > @ the Pickup Bed (General Topics) > Thread: 5 speed swap question
bwaits
posted August 08, 2005 05:47 AM
When swapping a 1981-1985 Rx7 5 speed into a repu will there need to be any modifications to the drive shaft?
My shaft seems to short in the front section in front. I am working blind as far as the engine location compared to stock.
-billy
ReSpeed Online Catalog
posted August 08, 2005 09:22 AM
-billy
Driveshaft should be just fine. Overall length of 81-85 tranny is same as REPU.
I can say that the 79-80 bolts up better, it does need a small plate to attach tranny mount to tranny crossmember. about 4" x 4" with four holes in it.
bwaits
posted August 08, 2005 10:07 AM
great......
I guess I need to do some more measuring and fitting. I am pretty sure I have the engine the correct spot - but the drive shaft is to short.
I will keep messing with it.
-billy
bwaits
posted August 10, 2005 05:42 AM
If someone could grab some measurements for me that would be great.
Front of the frame to the front of the engine.
I need the length of the stock yoke on the front of the driveshaft. Say.. centerline of the u-joint to the front of the snout.
Length of the drive shaft from the pivot point in the middle to the front of the shaft.
If anyone has access to a drive shaft to measure it would help allot.
-billy
kansei
Wankelized
posted August 24, 2005 07:38 PM
Edited By: kansei on 24 Aug 2005 19:39
Don't have the measurements for you Billy, but the 1979 & 1980 SA gearboxes are the only ones that will bolt up without major modifications other than the trans crossmember mentioned already (ask Charles- he makes them). The 1981-1985 transmissions have the shifter set further back, and will require modifying your floorboard, whereas the '79-80 trans will pop up right where the stock REPU shifter would be, to my knowledge. I know Charles did this (1979-1980 5-speed) to his truck (the red one), and I plan on doing it to my '75 when I get that far into the project.
Neal.
posted August 25, 2005 08:47 AM
Edited By: klaus42 on 25 Aug 2005 08:48
A couple'a measurements for you:
1.) Center of front U-joint bearings to tip of 'snout': 6.5"
2.) Center of middle (carrier) bearing mounting bracket (measured to very middle of the ovall-y, adjustable-mount bolt holes...) to center of front U-joint bearings:
27.5"
--Mind you, these are 'rough' tape measurements...--
...hope that helps... :)
bwaits
posted August 26, 2005 09:42 AM
Thanks.
Between Charles and your numbers I know it is the front snout that is wrong. PO must have swapped it for a pinto unit.
I will swap out the snout, machine my driveshaft to diff mount and I will be ready for the 4 link install.
-billy
EricHappyMeal
posted September 25, 2005 12:33 PM
Neal.
what needs to be done with the trans crossmember with the other trannies?
Whats up with cranberries?
        Click here to visit EricHappyMeal's homepage. Click here to send EricHappyMeal an AIM message.
FLIBOYZ6
great
posted October 13, 2005 01:04 AM
BEFORE CUTTING INTO THE DRIVE SHAFT I WOULD SUGGEST CHECKING THE FORD COURIER THERIR DRIVESHAFT THEY CAME IN 4 LENGTHS DEPRNDING ON THE YEAR, THE TRANS AND THE ENGINE.... ITS WHAT MY DAD HAD TO DO FOR HIS ITS GOT A TRANS FROM AN 84 RX-7
0.033226013183594 seconds processing time
