Index > @ the Pickup Bed (General Topics) > Thread: THE HOLE SHABANG!!
Dragular
posted July 29, 2005 11:57 PM
THE HOLE SHABANG!!
Hi my name is JD, I just got a 75 REPU from my uncle. This truck has been sitting for about 4 years and im getting ready to do a major restoration job. I need to know if the Courier has the same front end as the Repu because i can only find the front end parts for ford? And will thr brake rotors be the same as well? im really wanting to see this truck come alive again and i need some info of any kind... it would help alot thanx.
        Click here to send Dragular an AIM message.
posted August 01, 2005 08:24 AM
Search for an older thread...
...in this section of this forum entitled "Aftermarket Part Numbers........" by our fellow member Ken, (nwaco), for the whole scoop on suspension & brake aftermarket part numbers, all REPU-specific.
You can even print it out for yourself...
Beware; some courier stuff is 'almost' the same... but not quite, or perhaps as heavy-duty...
For example: You could swap in courier front spindles, and they do work... but, they're missing the 'lip' to mount the stock wheel center rubber holders...
Regards, and welcome to the forum! --Klaus
Dragular
posted August 01, 2005 05:04 PM
Thanx!
Alot and im happy i finally found a place were i can learn about my truck. I will be posting pics as i go but.... How do you?
posted August 02, 2005 10:05 AM
Pic Posting...:
...all depends on what you're running for a system/browser/etc. ...not to mention how that all interfaces (or not) with where you wish to post... (?)
I'm a bit of a 'teknopesant' myself, so I found it was simpler for me to post pics at the MSN site, therefore my pics are there...
I'm sorry, but I'm really not the expert to give advice on pic-posting/uploading to the web... just yet.
Best I can suggest is, read the instructions carefully, then read 'em again... then try, and if all else fails, ask someone who knows more than me!
Good luck!
0.02283501625061 seconds processing time
