Index > @ the Pickup Bed (General Topics) > Thread: ...drifting...!
tobanybe
posted July 08, 2004 01:54 PM
...drifting...!
wondering if anyone is into drifting here? It is so awesome!
posted July 09, 2004 12:46 PM
Is it? I've gone into a four wheel drift in my red REPU. That was kinda fun.
tobanybe
posted July 09, 2004 01:57 PM
drift in repu!
really ... in a repu ... i thought about making one of mine compatible, but lots of work to do.
do you have lsd? i am a big drift fan with a goal ... many goals actually.hows the 20b coming?
tobanybe
posted July 14, 2004 05:14 PM
man thats cool ... pics would be great if you could.i figured the play in steering and the "big" factory wheel would make it harder, the pull out e brake too if ya had to use.Did you heel-toe?How was you repu set up?or was it stock?i'd like to figure out a better suspension, and rim/tires ...
locally i am in process of settin up rotary meets and some races if they want ... hopefully it will bring the rotorheads or at least the rotary owners together here.Wish i had a camcorder!
klaus43
posted July 15, 2004 07:13 AM
Don't even get started...
...pulling on that E-brake! Save it for the true emergency... or just set it when you park. The back end tends to lock up first anyway...
You might wanna try bringing your stock suspension back to 'snug', prior to deciding what mods you really want/need... then upgrade your front sway bar...
0.025509834289551 seconds processing time
